Help with re-appearing objects
March 30, 2009 12:00 AM
In case you still cannot see the project, I'll give a quick overview of what I did.
Created action groups for each swap of balloons. For example, I have an AG that hides Salesman 1 and shows Salesman. I have another one that hides Customer 1 and shows Customer 2.
Created an action on the speech balloons to run the swap actions on a delay. So, when Customer 1 shows up, the AG to swap Salesman speech is run, but I put a delay of 3 seconds (though it should be longer, I'm sure). Likewise, when Salesman 2 shows up, the AG to swap Customer speech is run with a delay of 3 seconds.
I hope that makes sense. It should make more sense if you can open the project.
Kevin
