Help with re-appearing objects
March 30, 2009 12:00 AM
I just took a quick look at your title and Kevin is correct. One thing you could try is simply changing the On Timer to On Show for the actions at the page level and make the delay for the actions the same as what you had the timer set to. For instance, if your On Timer was set to 13.0 seconds, then make it an On Show action with a delay of 13.0 seconds.
