Help with CSS on Lectora
I don't think that in general you will have much luck. Create a sample page with a couple of formatted text blocks. Then publish and look at the HTML source. You will see separate style sheets for each text DIV which as far as I can tell, override anything at the generic level. Lex_tensions may be have some info if he/she posts here.I don't think that in general you will have much luck. Create a sample page with a couple of formatted text blocks. Then publish and look at the HTML source. You will see separate style sheets for each text DIV which as far as I can tell, override anything at the generic level. Lex_tensions may be have some info if he/she posts here.
