Help Technical Problem
Have you moved this file from where you originally created it? Perhaps not all of the image files got moved with it; which is what is sounds like. It sounds like it has lost the link to the image file for everything you used in it.Have you moved this file from where you originally created it? Perhaps not all of the image files got moved with it; which is what is sounds like. It sounds like it has lost the link to the image file for everything you used in it.
