Help publishing to Rustici LMS
 I used Test Track to test my courses and have never encountered the problem you described. I'm wondering if you could force the AICC_Lesson Status variable to say "Unknown" or "Incomplete" until you have a score on the test. That would simply be an action with a condition in the Title section. You would obviously need another action after the test has been passed. This doesn't solve your problem, but may provide a work around.
mikeg said:I have a course which needs to be SCORM 2004 and publish to the Rustici Test Track LMS. Currently, if I open the course and exit after a few pages the "Success Status" says "Failed". It should say "Unknown" This is the first problem I have encountered and I know it will lead to bigger problems when I try failing an dpassing the test portion. Is there someone out there that has been through this issue and could maybe help me out with some advice?
