Help publishing to Rustici LMS
I have a course which needs to be SCORM 2004 and publish to the Rustici Test Track LMS. Currently, if I open the course and exit after a few pages the "Success Status" says "Failed". It should say "Unknown" This is the first problem I have encountered and I know it will lead to bigger problems when I try failing an dpassing the test portion.
Is there someone out there that has been through this issue and could maybe help me out with some advice?
