Help! png.s not transparent when publish
August 18, 2007 12:00 AM
This would differ from what IE you use.It is commonly known that IE 6 is not able to handle transparent PNG's by default. You need some fix or add-on or something to enhance the browser. If you use IE7 and it still does not show correctly then maybe you should consider exporting the PNG-files in either different formats (lie GIF) or with a different setting in quality.Sure hope this helps!
