Help! png.s not transparent when publish
August 18, 2007 12:00 AM
What are you using to create the PNGs? I ran into a similar issue here using Fireworks 8. Images would be transparent in design mode, and in a EXE, but not when published to HTML. I looked around and found information from Adobe on saving as a Flattened PNG, going into the Options, and turning on the alpha channel transparency. Now the images work properly published to HTML as well. For that matter, it also worked with other applications that didn't pick up the transparency correctly. Even with IE6- although our IT staff may have patched that.If you are not using Fireworks, your mileage may vary. Hope that helps!Sean
