HELP ME OUT: Slider jQuery Mobile devices
January 15, 2016 12:00 AM
Hi developers, I ve created a neat slider based on the tutorial of Sergey Snegirev. Using jQuery.
Unfortunatebly this slider does not work on mobile devices (IOS Android). Can anyone help me out?
Found furf, but I don't know where to add this and or modify...
See attachment for current slider page.
Discussion (2)
try adding:
src="jquery.ui.touch-punch.min.js"
Between script tags, of course. I left them out above because the browser will interpret them as a script tag and doesn't show correctly on the screen.
Hi Darrel,
Thanks a lot. It was actually very simple; I was thinking way to complicated because of the steps of furf. Indeed, you just have to add the script as meta tags.
Works fine on android as well as IOS.
