Graphics resize when added to project
August 17, 2007 12:00 AM
Ludo wrote:
How do you set the background? Do you add an image and use it as the bottom layer, or do you just import when you are in the page (or chapter) properties?We have had no resizing in our background as long as I can imagine. We also use standard-size courses and exact equally sized images, but I have found no changes in either.What version of lectora do you use? Not sure what you mean by "setting the background" or by "bottom layer". I'm not familiar with any of the proprietary terminology used in Lectora discussion yet.Using 2007.Exactly following steps taught me in a basics course provided by a Trivantis employee, I dragged and dropped four jpg graphics that were going to serve as, essentially, the border on my 1000 x 650 page into the top title level. When I did, all of them resized themselves smaller by 2 pixels, either on the horizontal, the vertical, or both.In the lesson template provided in my Lectora basics lesson, led by the Trivantis employee, this process was completely successful and the four graphics remained sized properly.I also note that if I put in a graphic that is exactly the size of my project, 1000 x 650, it doesn't resize and fits exactly. Frankly, I'm beginning to suspect the way in which these four jpgs of mine were sliced up from one full size graphic.
