global volume control
I'm not familiar with using Lectora variables in Flash - although I know it can be done. But, you could integrate a "silent" audio into your Flash file and use it when your Lectora variable (Mute) is set to muted and then use your original sound file when the mute is off (sound on).This poses two potential problems. The first is that the audio in your videos is seperate and you can control that. The second is that there is potential you wouldn't have your audio sync'd with your video if the user decided to unmute the audio in the middle of the video. Sorry if I wasn't much help...just noticed that your post died and thought I'd add a couple of cents to the topic.
