Flash audio problem
I think a simpler solution would be to NOT play on load the audio file from the Flash file. I would give the user an option.Two buttons, and upon clicking one, an action will remove the other -this way the user cannot mistakingly play the audio twice. Do not preload the audio and you should elimiate this. I know this may not be what you want, but I think it is better to control the environment and restrict the users ability to convolute your course than to always make it the easiest for the user by auto playing the video.I currently have the same problem and had to give button options on how the user wants to view / hear. When they click one, the other is removed so they CANNOT click the other and have the audio over play the previous instance.I hope this helps.Good luckBradley FredrickInstructional Designer
