Flash audio problem
October 4, 2006 12:00 AM
I have a Lectora page that contains a Flash audio file. The audio plays when the page loads. On that same page I have a button that when pressed, opens a "pop-up" lectora page containing a Flash movie with audio. My problem - If the user clicks on the button to launch the flash movie page while the audio is still playing, then both Flash audios run at the same time. Is there a command I can attach to the button that will stop the Flash audio that is playing on the page and allow the Flash audio in the movie to play instead?I have a Lectora page that contains a Flash audio file. The audio plays when the page loads. On that same page I have a button that when pressed, opens a "pop-up" lectora page containing a Flash movie with audio. My problem - If the user clicks on the button to launch the flash movie page while the audio is still playing, then both Flash audios run at the same time. Is there a command I can attach to the button that will stop the Flash audio that is playing on the page and allow the Flash audio in the movie to play instead?
