Flash audio problem
I don't have time to look it up but I know you can control flash movies via javascript. You may have add an external html object with the javascript to stop your flash movie. Set it to initially invisible and on the button for the popup have an action to set the external HTML object to visible (it should run when it becomes visible) and use that to stop the audio. Also, in flash is your audio an event or a stream? If I have some time later today I'll play around with it.I don't have time to look it up but I know you can control flash movies via javascript. You may have add an external html object with the javascript to stop your flash movie. Set it to initially invisible and on the button for the popup have an action to set the external HTML object to visible (it should run when it becomes visible) and use that to stop the audio. Also, in flash is your audio an event or a stream? If I have some time later today I'll play around with it.
