flash and lectora communication?
The easiest way to do this is to create a button in Lectora to pop up your window. Make it not visible to start. Publish and look at the resuting code of the page for the javascript command for the button you just created. Then in Flash (whichever program you are using to create it) add an action script to envoke the Javascript command of the button.When the flash is then inserted to the page the button in flash will push the 'hidden' button in the course and cause the pop up.There are lots of preset commands for next page etc that are always the same but for an individual command I have always found this is the easiest way to do it.Neil
