Fixing resize problem before html publish
hey. u no how html publish screws up all your typesetting...!!!well if you view zoom out, you can see where it is going to hit you. it is so lame. you can have a whole bunch of exactly same size txt boxes and it will alter some of them. u can see a plus sign on the altered ones cause txt dont fit box no more. but in zoom out all their graphics are stuffed so dont try fix everything u see. how many years now has html typesetting been a problem???btw - u wont see all the typesetting shifts...Edited By: booboo on 2007-6-7 2:19:0
