Test Sections not returning values
Hi, I read AndyP's post on scoring sections and multiple tests - I had a 5 section test and wanted to display a overall result screen at the end but could never get the section scores to show. I created my own variables to add up section scores but they proved unreliable.So, I followed AndyP's advice and created 5 tests with the aim of creating an overall result at the end. The tests work fine - they display the results correctly. But when I try to add the test score VAR[TEST1_Score] to the overallscore variable, it does not work - it displays 0VAR[TEST1_Score] as its contents. Could anyone please explain how I access each test score and add it to the overallscore? I just tried displaying the AICC_Score instead of my overallscore variable but it did not display.Hooray - Ben sorted it out - I needed to submit the test to get the scores generated before I could play with them. Thanks mate! Edited By: booboo on 2008-11-19 22:30:6
