Exit Button Problem
From the edition of the Trivantis eNewsletter that just arrived in my email today...Exiting a Published SCORM TitleHave you ever had an issue with the exit button not working when publishing to SCORM? If so, make sure that in your Publish options, you check the option that says "Published Content will be Presented in a Separate window than the LMS.” This will enable you to use the Exit Title action in Lectora when publishing to SCORM.Hope this helps!Laura
