Drag and drop / Match the following - Test Results issue
Hi Ben,
Can you suggest me how to achieve it?
karthik8583 said:
Hi,
One of my client has reported a issue in the assessment created using Lectora. In the test result section we will get the report based on the questions which is right or wrong in the format of 1-12,2-7,3-11, but the client say's 'but you don’t know if the 11th item was “XXXX” which you picked or something different. Can it be more obvious whether you got it right or wrong for each module without a lot of rework?'
Is it possible to display the content/value of the drag item like eg: 1 - "XXXX" in the test result section?
