Drag and drop issues
August 15, 2006 12:00 AM
Hi.I have a problem there i use 4 drag pictures to be placed in a drop picture. The problem seems to be that i need to drag the item in same order as i put them in to the d&d question. If i dont drag the first item first and so on, the feedback will be incorrect.Does any one know about this problem, or even better, have a solution to it?PAG
