Drag and drop issue
November 13, 2007 12:00 AM
Generally in Lectora, the drop points need to not overlap each other. I have not seen a good way around that. You possibly could have set each drag item up as a separate question and then overlap them but you would have to make sure only one drag and drop pair showed at a time. You could use transparent objects for the drop locations and hide and show it bits and pieces as necessary.Generally in Lectora, the drop points need to not overlap each other. I have not seen a good way around that. You possibly could have set each drag item up as a separate question and then overlap them but you would have to make sure only one drag and drop pair showed at a time. You could use transparent objects for the drop locations and hide and show it bits and pieces as necessary.
