Drag and Drop doesn't work
May 30, 2008 12:00 AM
I think it's your design that needs tweaking. Either the question is "Choose the three passwords that are 'good'," in which case you only want them to drag and drop three out of the six, or the question is "Categorize these passwords as 'good' or 'bad," in which case you should have two drop targets -- one for 'good' passwords and one for 'bad' passwords.Personally, I wouldn't have used a drag and drop question type for this at all -- I would have gone with a multiple-answer multiple choice question. But that's just me...Laura
