Drag and Drop doesn't work
May 30, 2008 12:00 AM
The problem with your solution (without adding custom actions and conditions to them as I've been doing) is that, using your second example, any checkmark image has to work with any of the correct passwords. Unfortuantely, the built in functionality requires that the a single drop image match up with a single drop target location. I'd be happy if they could change that default functionality (allowing the developer to specify multiple possible correct drop locations), but I figured it would be easier for them to change the functionality to just change the size of the drop target.Does that make sense?Laura
