Drag and Drop doesn't work
I understand what you all are asking for. I have wanted to do it too. You want to be able to categorize items and drag and drop them in any order into two buckets. (Actually in tonyz's case it sounds like you didn't even want to be able to drop the bad passwords).This isn't exactly what you wanted, but just an idea to try. Let's say you have 3 good passwords and 3 bad ones in a list (all mixed up in order). You could place drop locations over these passwords. Then have 6 labels. 3 good and 3 bad. The learner would drag the appropriate label over the passwords to indicate whether they think they are good/bad. You would have to have a done button to judge if they got question correct or not. Alternatively, you could have them drag checkmarks and x's to a drop location next to each password.Hope this helps. Michele
