Does anyone have experience with Lectora and the Surge Learning System LMS?
Hello everybody. I am hoping someone can help me with Surge learning LMS or with my issue in general. When i publish to scorm (both 1.2 and 2004) and upload, it works fine to the end but if i close part way through and then return to try and continue where i left off, i receive the following errors in order:
Note: "Privacy" is the name of the module.
"LMSSetValue ERROR: cmi.core.lesson_location to [a001_privacy_page_1.html]"
then when i click "Ok" i get another:
"Unable to find an API adapter"
then:
"Unable to locate the LMS's API Implementation. LMSInitialize was not successful"
then finally:
I have never ran into this issue before with any other LMS.
I tried checking and un-checking "Prompt the user to navigate to the last viewed page".
Thank you in advance.
Discussion (1)
This thread from 2013 has some suggestions.
https://rockstars.elearningbrothers.com/discussion/280680/what-causes-unable-to-find-api-adapter
The most common (and good) advice is to test in a free SCORM Cloud account (https://cloud.scorm.com). If it works there, it's reasonable to assume the problem is with the LMS.
