Difference Between Camtasia 7 for Lectora and Camtasia Product
Hi,
I finally had a chance to play around with the version of Camtasia packaged with Lectora Inspire. It seemed to be very similar in functionality except for when you want to Produce and Share... the only options are "Lectora Output" or share to screencast.com (a techsmith service).
Lectora output seems to only have one size 800x600 and one output file format -- FLV. If this is the case, this is very disappointing, as it's very limited from what is offered in the full Camtasia product. Trivantis should've been more upfront regarding limitations of the version they were packaging. It really forces you to buy the full product if you want more flexibility regarding output format/size options and optin to do other types of deliverables (such as CD, DVD, iphone, or ipod output).
Please tell me I'm missing something?
Thanks, Paul
PS - would really like to see differences documented so no new surprises- pointers to any existing docs would be appreciated
