Completion status problem
I am trying to get my Lectora test to track properly in Learn.com's LMS. The test sends the test results (grade and answers) but it doesn't send completion status. I have tried to set completion status based on going to the Results page (the page after the last question). I have tried using CMI_Completion_Status and AICC_Lesson_Status but neither one worked. I have been getting this error, "LMS Set Value Error". Here is how I have tried to set the completion status: On Show - Modify Variable - CMI_Completion_Status - completed - Set Variable Contents. I also tried not doing anything with these variables and the status remained incomplete. Does anyone have any ideas?I am trying to get my Lectora test to track properly in Learn.com's LMS. The test sends the test results (grade and answers) but it doesn't send completion status. I have tried to set completion status based on going to the Results page (the page after the last question). I have tried using CMI_Completion_Status and AICC_Lesson_Status but neither one worked. I have been getting this error, "LMS Set Value Error". Here is how I have tried to set the completion status: On Show - Modify Variable - CMI_Completion_Status - completed - Set Variable Contents. I also tried not doing anything with these variables and the status remained incomplete. Does anyone have any ideas?
