Combining random and not random questions
This is something you can do in Lectora. What you need to do is create test sections in your test and randomize the test section you want randomized and then include the questions you want to always ask the user in another section that is not randomized. To randomize a section, right click on the test section, select the section content tab and select the number of pages you want to randomize. Before you do this, make sure that you go into the test properties and deselect the random selection of pages option.This is something you can do in Lectora. What you need to do is create test sections in your test and randomize the test section you want randomized and then include the questions you want to always ask the user in another section that is not randomized. To randomize a section, right click on the test section, select the section content tab and select the number of pages you want to randomize. Before you do this, make sure that you go into the test properties and deselect the random selection of pages option.
