Changing Fonts
Did it change anything? What version of Lectora? 2005 and 2006, that tab will change all blocks that are set using the base font that have not been changed. i.e. if your default font is 10 pt Arial and you have 2 text blocks on a page, one 12 pt Arial and one 10, it will change the 10, but not the 12 - it changes all the text that have not had special formatting applied to them.Did it change anything? What version of Lectora? 2005 and 2006, that tab will change all blocks that are set using the base font that have not been changed. i.e. if your default font is 10 pt Arial and you have 2 text blocks on a page, one 12 pt Arial and one 10, it will change the 10, but not the 12 - it changes all the text that have not had special formatting applied to them.
