Bulk enrolling over 300 users into Coursemill and Enrolling in a courese
What is the format and instructions for bulk enrolling over 300 users into CourseMill (https://trivantis.com/help/CourseMill/8.1/en/AdminGuide/index.html#2412.html)? Can you also bulk enroll/register students for a course?
Discussion (2)
Hi @whatcher-8448 Batch user updates will update the fields that are included in the batch file. Use the same method as you would for any bulk/batch action, but only add data to the fields for the curriculum and course that you wish to update. Note that the first 4 fields, Org ID, Student ID, LastName, FirstName are required. Use the headers as noted below for the curriculum or course IDs
CurrID - Header value
Curriculum ID of the curriculum into which the student should be enrolled
CourseID - Header value
CourseID of the course into which the user should be enrolled.
It is recommended that the course has at least one content item.
If you need more assistance, please email support@elearningbrothers.com
Thank youq!
