Audio question
November 6, 2008 12:00 AM
Possibly what might be happening is that if you move the mouse too quick you confuse the issue. If you have a Mouse In to play but move the mouse too quickly to another Job image, you might be playing the audio from another image because you went so quick to stop the first audio before starting the next.. I encountered this before - and yes it is very frustrating. However, there was a solution.I had to put STOP audios at all images, for all 6 [Job] images, before I used the Start Audio on a Job image. That way I was guaranteed to stop the audio before another one played.I'd also keep the Stop audio on each image just in case you have a NORMAL user who does not go all spastic and jump around freakishly, which MIGHT be causing your issue.Let me know if you can try this, or need further assistance.
