Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Audio properties display problem when published to html
@mrmad1966
June 12, 2009 12:00 AM
I believe if you use wma or flv files that you can attach a Pause action to the JPG and pause the audio file. You may have to get a little tricky and use a variable to remember whether the audio is paused or playing. Then you could add another action to the JPG to play the audio if it was paused.
mrmad1966 mrmad1966
@mrmad1966
View Profile
More From mrmad1966
On Mouse Click Not working, even in run mode
October 24, 2014 Reply 0 Upvotes
Can I remove the play button in the centre of a paused video !
April 9, 2013 Reply 0 Upvotes
One play/pause at root level to control ALL flvs in title?
November 3, 2010 Reply 0 Upvotes
Flash interaction opens twice while opening a pdf
August 12, 2009 Reply 0 Upvotes
ActionScript Reqd to trigger Lectora Even
March 11, 2009 Reply 0 Upvotes
© 2025 ELB Learning. All rights reserved.  | Terms of Use  |  Privacy Policy
Join The Discussion
Sign Up Login
