Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Audio properties display problem when published to html
@mrmad1966
June 12, 2009 12:00 AM
Thanks for this Ben, all my audio has already been converted to flvs as I am using the events functions. It appears at first glance you cannot attach any actions to the jpg as it replaces the standard speaker icon within the audio properties...If you can think of any other alternative I'd be grateful !!
Thanks again..
John
mrmad1966 mrmad1966
@mrmad1966
View Profile
More From mrmad1966
On Mouse Click Not working, even in run mode
October 24, 2014 Reply 0 Upvotes
Can I remove the play button in the centre of a paused video !
April 9, 2013 Reply 0 Upvotes
One play/pause at root level to control ALL flvs in title?
November 3, 2010 Reply 0 Upvotes
Flash interaction opens twice while opening a pdf
August 12, 2009 Reply 0 Upvotes
ActionScript Reqd to trigger Lectora Even
March 11, 2009 Reply 0 Upvotes
© 2025 ELB Learning. All rights reserved.  | Terms of Use  |  Privacy Policy
Join The Discussion
Sign Up Login
