Audio properties display problem when published to html
Ben
Your thoughts on this would be appreciated..My original application had 3 frames. A title at the top, a permanent content frame on the left and my main frame for my conent., it appears it is this that is giving Lectora some problems. If I create a new title and "import from existing title" the contents of the original main frame then my pausing and playing of my sound flvs work fine. As soon as I duplicate my working example back into the frames it does not ! Any ideas ??
Thank You
