Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Audio properties display problem when published to html
@mrmad1966
June 12, 2009 12:00 AM
Just saw this in another post.
" To convert the file to FLV format, just right-click it and select Convert to FLV. Or, if you want to convert all the audio, select the box to compress audio on the Compression tab when you publish." Diane Elkins
mrmad1966 mrmad1966
@mrmad1966
View Profile
More From mrmad1966
On Mouse Click Not working, even in run mode
October 24, 2014 Reply 0 Upvotes
Can I remove the play button in the centre of a paused video !
April 9, 2013 Reply 0 Upvotes
One play/pause at root level to control ALL flvs in title?
November 3, 2010 Reply 0 Upvotes
Flash interaction opens twice while opening a pdf
August 12, 2009 Reply 0 Upvotes
ActionScript Reqd to trigger Lectora Even
March 11, 2009 Reply 0 Upvotes
© 2023 ELB Learning. All rights reserved.  | Terms of Use  |  Privacy Policy
Join The Discussion
Sign Up Login
