Audio issues
July 30, 2008 12:00 AM
If you can't play the FLV files locally in the browser, then there is a local security issue. I am not sure if Articulate produces swf files or FLV files and whether or not they are played in a browser or outside of the browser. Playing FLV files in a browser is totally different from playing the files locally outside of the browser. One way to test it is to go to Adobe's website and setup your plug in to allow the content to be displayed. Go to the following url and select the option to always allow and see if you can play the content locally. http://www.macromedia.com/support/documentation/en/flashplay er/help/settings_manager04.html Also, another thing you can check in your browser settings under Tools, Internet Options, Advanced, Security is to enable the option that allows active content to run locally on my computer.
