Audio .flv files not playing when published to single-file executable
July 14, 2009 12:00 AM
There is a compression tab when you publish; try un-checking the compression for your audio files and that may fix the issue. If you had it un-checked before you sometimes have to re-check if after an upgrade.
conniew said:I recently upgraded to Lectora 9.2 from 9a. Before the upgrade, I had published some courses as single-file executables that contain audio .flv files and had no problems with the audio playing. I made changes to these courses and re-published them as SFEs after the upgrade. Now none of the audio .flv files play, although the .wav files play fine. Any ideas?
