Audio events not triggering actions
I have some audio into which I've inserted a number of events. At each event I've set an action to display a "hidden" screen element. When testing within Lectora it works as expected (the hidden screen elements appear) but when I publish most of the audio does not trigger any actions.
One piece of audio does but I can't tell how it differs from the other audio which doesn't.
I've tested locally, off a web server, and off the LMS all with the same negative results. I have the latest version of the Flash Player installed and the latest IE 8 installed.
Is there something I need to do to get this to work.
Andrew
