Hi Red,
I just looked back at one of my old titles to see if I had missed anythign in the instructions. For the Audio buttons on/off the on click action is to play or stop the audio. There are actions underneath the buttons. On the On button there first action is to hide the audio on button and the second is to show the audio off button. The audio off button has the same two actions only it hides the audio off button then shows the audio on. Both buttons are set to be initially visible but the audio on button should be layed on top of the audio off button so it is primarily seen.
Shawn
