Audio FLV files with cue points from Soundbooth
The original file came from Ben Pitmans website so I dont want to post a file to protect his work.... But I can tell you more about whats going on... I am using a placholder audio clip at the top level then on each page running a change contents action for the audio on that page.... Usually you could double click the audio to get the properties window and use the event tab actions to control what happens at the marker, but since the audio clip is not on the page... what do I do to get the action to happen????
