AUDIO - AUDIO - AUDIO
Red, I tested the file and the logic is correct, then I went back and republished an old course that has the same logic in it and the feature is not working there. I'm going to contact Lectora Support and see what is going on. I even tried turning off the Audio Compression feature to force the course to use the MP3 file and it still didn't work automatically, but the audio played fine when I clicked on the audio button.
Shawn
