AUdio and vents
April 27, 2007 12:00 AM
If you mean by "event" a Lectora action, then yes, that is true. The User Guide says not to do that because it has unpredicitable results depending on the browser.If you mean by "event" a Lectora action, then yes, that is true. The User Guide says not to do that because it has unpredicitable results depending on the browser.
