Audio, 2008, and Actions
Good afternoon-I'm using Lectora 08 and having some trouble with actions and audio in the new version (used to work fine on 07, so I assume it has something to do with the flash conversion). Two different trouble spots.1- I have a piece of audio which was edited in the Lectors audio editor. I added several events to have images appear in conjuction with that piece of the audio. I have 3 images to appear at different times, and 3 events within the audio set to "show" each image. The image properties are set as "always on top" and NOT "initially visible". This works fine when preview mode and when published as .exe. It does not work when published to HTML. 2- I have a scenarios where the user must click a yes or no button and there are action groups tied to the selection. One of the actions in the group is to play either a foghorn (for an incorrect answer) or an applause (if correct). Same scenario works fine until published to HTML.My guess is that this pertains to audio being converted to flash but I'm unsure how to fix.Any insight would be appreciated!!!Thanks,EamonEdited By: Eamon on 2008-2-20 13:45:40
