Audio, 2008, and Actions
I had that same problem and turned off the auto-compression when publishing and it fixed the issue. There is a Compression tab in the pop-up box when publshing your program, if you unclick the check boxes you should be fine.I had that same problem and turned off the auto-compression when publishing and it fixed the issue. There is a Compression tab in the pop-up box when publshing your program, if you unclick the check boxes you should be fine.
