Alt tags with entry fields
There's actually no ALT tags associated with entry fields. The only thing Lectora does is give it a "title" attribute for screen readers. It seems that IE likes to then display this as a tool tip. It's a good suggestion though to allow you to remove it.There's actually no ALT tags associated with entry fields. The only thing Lectora does is give it a "title" attribute for screen readers. It seems that IE likes to then display this as a tool tip. It's a good suggestion though to allow you to remove it.
