Alt tags with entry fields
February 21, 2007 12:00 AM
Since it's based on the title of the entry field, make the entry field name something that either makes sense to the end user or is small and nearly indistinguishable. A single underscore would work, or if you have default text in the entry field, make the entry field title the same as the default text. Just a few ideas.
