Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Alt tags with entry fields
@muncan
February 21, 2007 12:00 AM
How about turning them off when you publish? Have you tried that?How about turning them off when you publish? Have you tried that?
muncan muncan
@muncan
View Profile
More From muncan
Deleting the lectora cookie??
January 8, 2010 Reply 0 Upvotes
Lectora > XML > PDF
January 10, 2008 Reply 0 Upvotes
Can you force the cursor in an entry fiel
August 17, 2007 Reply 0 Upvotes
Hide hyperlink outline
May 22, 2006 Reply 0 Upvotes
Join The Discussion
Sign Up Login
