Adobe edge and manipulation of variables
Is it possible to create an interaction in Adobe Edge Animate and have it communicate with Lectora in the same fashion that Flash was able to do (e.g. modify a variable, get a variable, change pages, change visibility, etc...) with ExternalInterface? Would love to hear thoughts on this.
Seth
Discussion (1)
Yes, absolutely. Edge can run custom JS code, therefore it can control Lectora.
