Activate next btn after Flash finished
There is post about it here: http://community.trivantis.com/forum_posts.asp?TID=5422&KW=a ctionHideIf you are using flash player 7 or below you can try the getURL method mentioned. If you are using flash player 8 or 9 with AS2 use the ExternalInterface method. If you are using flash player 9 AS3 let me know and I'll dig up the code for it.
