Action: When Done Playing problem
April 5, 2007 12:00 AM
I'm not sure how you open a captivate file in Flash; importing the swf doesn't show any of the actions you speak of. And you can't open a .cp file in Flash. This is for Flash 8, Captivate 2.After some experimentation, it looks like Lectora thinks the animation is done playing after the first bit of animation is done inside Captivate (the end of a mouse movement, for instance), but not when the entire file is done playing. So it executes the action too soon.The only way I've found that works is setting the action from inside Captivate, as suggested elsewhere in the forums: in the project preferences, project end options, Execute JavaScript, click "..." button and enter trivNextPage(). Do this for every .cp file you want to load the next page in Lectora on animation end.So how do you control a Captivate movie from Lectora, as in the On: Done Playing action? It doesn't seem to work from that angle. You'd better hope you have Captivate installed and access to the original Captivate .cp files...
